butzla
- Feb 5, 2008
In the market for a LS 130 sander. I need to sand some complicated profiles so I thought the do-it-yourself kit might be the way to go. Is this a 'use once' item or does it spring back to original shape so I can reuse on a different profile? Also for you LS 130 owners, what extra pads are a good bet? I see it comes with a 90 degree but they make an 89 degree pad for sanding corners. I know it depends greatly on my own needs but what extra pads have you bought that you recommend or regret?
http://www.bobmarinosbesttools.com/product_detail.html?sid=7539aeddbd358d84ebee53888fe4266d&pid=490780
