Lumberyard II and shelf for gardening tools
Coliban
Hello,
after finishing the lumberyard, (http://festoolownersgroup.com/member-projects/small-lumberyard/msg406439/#msg406439) my wife saw, what was possible, she wanted a shelf for the gardening tools, which until then, were flying around in the carport.
It turned out that the lumberyard i´ve build was too small, since i go sometimes into the forest and get some wood for heating. View attachment 1
This ist the already finished shelf and the second lumberyard (temporary used, it has to be sorted):
I used the DF500, the OF1010 and the Mafell P1cc for the 9cm beams.
The DF500 helped me in cutting all the connections:
I used nearly no screws and nails, i cute the groves with the OF1010 and then inserted the mortise for the back and the sides.
I build the lumberyard for about 4 tons of wood, the DF500 is just fine for that task
Thank you, neilc.
It is still a little bit rough, but i think, for lumberyard sufficient.
