I thought about this idea of using 20mm bolts the whole week.
I have a bunch of these and checked they were fitting well, and they did actually.
Then I remembered about that domino jig I saw recently:
http://www.lairdubois.fr/creations/484-la-dominoteuse.html
I spent some time on the CAD software, fired the 3D printer up and ended up with this:
The shape is computed using the golden spiral formula, the bolt being at the center of the spiral.
The hex recess is adjusted so there is almot no play when the bolt is fitted.
I double taped some P120 sandpaper on the side to get a better grip.
It works so well, it can stand manual handplaning.
With a left and a right version, it is quite versatile and can be combined with other festool accessories.
Thanks again, I would not have thought of this without you
PS: for those who noticed the fuzzy surfaces I got on these, it comes from the extruder motor that is about to give up...
