Do any of the Mafell/Bosch tracksaw users use the angle/mitre guide adapter? If so, how good is it and does it enable quick repetitive work, or is it a bit fiddly to use?
They work ok. If the part is flimsy and you need and on it, and a hand on the mitre and a hand on the saw the you need to be like Durga, otherwise it works well.
Most of the time I throw a clamp on it when it is nigglly.
