Dave Rudy said:With the OF1400 comes an adapter to "PC" style guide bushes. So all of the imperial sizes including 1" are available. I decided to use the 1" OD ring with the Festool 20mm bit.
I think that combination wasn't available to me when I set up to drill the grid--1400 didn't exist. I have an adapter (from Leigh, I think) to use PC guides with my 1010. OK, I won't whine about the 30mm bushing's availability anymore.
I suspect that dust collection from the 20mm hinge bit would be better with the 30mm ring than with a 1" (25.4mm) ring, but I have no proof.
One question on the hole drilling system -- doesn't each row have to be separately aligned with care to keep the entire grid equidistant? That is, where the hole drilling system will guarantee accurate spacing along a row, don't you have to precisely reset the guide rail each time to guarantee accurate spacing between rows? If so, it seems to me that a template would be easier and more accurate.
Yep Dave, everything you're saying is correct. I used the guide rail with holes to (carefully) make the template.
On the old group I showed some aluminum locating bushings I made to accurately position the rail for the next row. I should move that info over here. Gimme a day or two.
