ryanjg117
- May 18, 2015
I've been tidying up the shop and got rid of my old offcut storage cubby on casters. I made the mistake of making the walls on the cubby far too tall, which made it a huge pain to "dive in" and find anything of value. I've since learned the value of accessibility, which got me to thinking...
I'm repurposing a good-sized Madix shelving unit, rated to 1400 lbs per shelf. A bit lighter than a full-sized pallet rack but not my much. The rack measures 8 feet long, 2 feet deep and about 6 feet high overall. Pictures below.
I'm aiming to reserve the bottom shelf for a massive, single drawer, dimensioned 8 feet long, 2 feet deep and 18 inches high. I'd like to keep this one long drawer because I often have long but narrow offcuts and no place to really put them. This will solve that, plus accept all the really small stuff.
I could build a cabinet to house this drawer, or just keep it open and use under-mount slides, which I think is what I would prefer. Undermount slides would also solve the problem of sagging, which over a 8-foot long stretch is something I need to consider.
I was considering using something like Blum Tandem 569A under-mount drawer slides until I realized they are really intended to be located in the bottom corners of a cabinet carcass and can't be mounted in the middle underside of a drawer due to their flange.
It looks like there is an "under-mount drawer slide" classification but I'm not coming up with much in the way of specs.
Update - Looks like Accuride makes a (very expensive) under-mount, Model ST8201. Still has a flange though, so it wouldn't be possible to mount center-bottom. About $200 for the pair but they will take 400 lbs of static load.
I don't see this holding more than 500 lbs of materials fully loaded, so I would like to aim for overall capacity in that range.
Starting to realize the flange in most drawer slides lends a lot of strength, and "center mount" slides, because they don't have those flanges, are incredibly weak. So I might have to go for the Accuride option above or similar, and perhaps stiffen the underside of the drawer with some metal angle embedded into the bottom.
Any ideas?
Picture of the rack and the sketch of the drawer pull-out:
Any ideas?
