Making MFT Top: any methods other than LR32/Parf Guide Sys/ CNC
Prizen
Hi all
Are there any reliable methods to make a MFT top without using LR32 / UJK Parf Guide / full CNC / those phenolic resin 30mm hole jigs + copy ring and router?
Ive used Parf Guide and Hole Jig + router methods without desired accuracy, and the CNC option or LR32 are too expensive (I wish to make several tops)
So, you want to make an MFT without any of the tools or jigs that are used to make MFTs?  The problem is that you are making a repeating pattern. This usually means a form of jig. Otherwise if you use a form of repeating measure , you end up with the compounding of your measuring error.  I have had good results with the LR 32 and 30mm jig systems. There are people that make their own LR32 system jigs. This may be your best bet. To make your own LR32 rail. There are threads on this on this forum. Best of luck.
Yeah, there is,  you contact/go too a festool retailer, give them $141 and have a MFT top.
I don't know what people value their time/hassle/tools/materials at.  I just don't see how this isn't always the answer.
Not sure if it is still true but they offered the top for the older MFT 1080 for less money and it is close to the size of the MFT/3 top.
That is easy. It is not exactly what you want. Different material. different dimensions, you may already have the materials. Just to mention a few. Then there are people who enjoy making their own tools and fixtures.
BTW the ferstool table is 225 plus tax, that is just for the top. Last time I made one it took less than 15mins. So, 20 bucks for materials, 15 minutes.... that makes my time worth 4x200=  :) I know I do not bill 800ish an hour, and it is not much of a hassle.
Then there is the simplest answer of them all. BECAUSE.
There was a guy that used pegboard and a drill, and had a video  I forget the guy's name, but thought it was Anthony.  Just to time consuming in my opinion.
You might be surprised how reasonable the CNC option is. I had a 2400 x 1200 x18mm MDF top routed for AU$80. That included the MDF. Now, I did know the guy that did it, but even if you double that price it's still a great price.
Thanks for the welcome guys! My main tooling is :
OF1010, RO150, CT Mini, Mafell Track Saw, Mafell P1CC Jigsaw.
I also have quite a few bench dogs. Using the UJK Parf System I wasted three sheets of MDF trying to get the alignment right. It was close but never acceptable, even for woodworking levels of accuracy.
I could have a CNC job, but quote is 130USD equivalent for one sheet plus the delivery, there is nowhere local with the capability.
Perhaps a replacement top purchase is the best course of action
You are on the right (Festool?) track  ;)
None of the jigs available will give you accuracy across the tabletop besides using a largest template or LR32 system.
I elaborated on it in a lengthy post in mft3 top replacement
Thanks. I've considered the LR32 system but reviews are very mixed which doesn't make it an easy decision. And indeed it is expensive for what it is.
+1 (plus my $0.02) for purchasing a replacement top, especially if there's no CNC shop in your area to help reduce the cost enough to make the back & forth trip worthwhile (plus the sure-to-happen hour you spend chatting).
I'm also a big believer in Murhpy's Law, which for me (experience talking here...), goes something like: I can save $30 by getting a local CNC shop to do one up, but I get in an accident driving there and now I'm out some real money, plus the time needed to deal with something else.
Suddenly, placing an order to save time and unforeseen expenses doesn't sound so bad. [big grin]
I'm curious what accuracy issues you had with the UJK system as it and the LR 32 system are probably the two most accurate home brew methods.
I don't know how much time you have for woodworking. Spending money on a jig and then hours on making a replacement top is unthinkable to me as I value my shop time more than the cost of a new top which should last for years, say 6 or 7 for a hobbyist. Cost-wise, it's just $20 to $30 a year over 6 to 7 years, or $2 to $3 a month give or take. If I wanted to save $150 US for a new top, I could just skip eating two or three meals at a restaurant.
If one does woodworking for a living, the expense is tax deductible.
I think perhaps I'll wait for the new Festool Table Saw and leave the MFT for clamping duties.
Anyone know when the new table saw will be available in Europe?
If you need several MFT tops, purchase one and replicate it into as many as you want using pattern router bit. Probably the fastest method there is.
I used my old top to make a new one.  Make sure you have some good holes in your old top that are accurate and not torn up.  Also make sure you have at least two rows of good holes in your old top.
Start in a corner and clamp the old top on the new top.  Use a 15 mm drill bit to bore out the bulk of the hole in the new top thought the hole in your old top.  Try to stay a close to the center as you can.  Use a top bearing router pattern bit with a 1/2 inch diameter [I like the Freud - 50-101 Pattern Router Bit Top Bearing 1/2"D 1-1/4"CL 1/4"SH].  This bit is long enough to extend through the new top and cut the hole in one pass.  As a caution, this is not a plunge type bit so do not turn on the router and plunge it into the hole.  I keep the router off and make sure the bit is entirely inside the hole you just drilled and the bearing is deep enough to ride on the inside of your old template hole and below any saw kerfs that may exist in the old top.  Turn on the router and ride the bearing on the inside of the old hole to make the new top match up perfectly.  On my first one, I was not down deep enough and cut both the new and old top on one of the holes.  I can't use that hole again.
You can use large dogs to connect the old top to the new top to allow you allow you to continue your hole pattern until all the holes are done.  This method works for all style tops, MFT3, 1080, mini, MW 1000 extension table, etc.
The time it takes depends on how many good holes you have.  The lost time is in the moving of the jig to extend the holes.  It took me about just under an hour the first time to make an MFT3 top.  It has taken me about 45 minutes for the additional tops I have made.  I ended up with really precise hole patterns.  I am thinking of making a large jig for future use.
Good luck.
I tried the Woodpeckers jig, but couldn't get it to stay put well enough to give me the accuracy I wanted.
Plan B became the CNC route (sorry, couldn't resist) and did some research for options in my area.
BTW, my top is 860 x 2185 x 19 (mm).
I found seven places advertising custom CNC work / sign making and submitted RFQs to all of them.
Two didn't reply, three were absurd (= not interested in one-offs), one was high, one was at the high end of my budget.
We talked, came to terms ($200 including the 19mm MDF) and I got my top.
I don't have a truck, but Home Depot does, so add $20 for the rental.
It is square, accurate, and I'm petrified to make a mark on it.
In hindsight, I would have liked to apply a light seal coat *before* the machining.
I'm reluctant to now for fear it might invade the holes and make them too tight to use.
HTH and best of luck.
That’s a very good idea but several people who added a finish after matching say it had no (or minimal) effect on the fit of the dogs.
You can use thin pieces of flat stock like 6mm mdf or Masonite as sacrificial covers for the panel. Keep a stock of different sizes nearby and your panel will stay pristine for a long time. My MFT-1080 has only one kerf in it after ~12 years.
