I just bought a Makita 36 volt track saw package. $499 for the saw 4-5ah batteries charger and a 55” guide rail in two Makita systainers. This saw performs wonderfully. I used it on my new cutting station top that was made with the UJK Parf Guide system (another great tool). The accuracy and cut quality right out of the box were great. The saw also has plenty of power. First cut I straight line ripped a piece of 8/4 hard maple with no trouble what so ever. It also left a perfect glue line rip. The next cut was a crosscut in the same material. It left such a smooth surface on the end grain that no sanding was required. I was so impressed I decided to test it further by cutting chip prone 1/4” luan plywood. The cut was perfect on the rail side and had very little chip out on the off cut. Then on to the ultimate test, melamine. I had a section of melamine shelving that I ripped about 4 feet long. The cut line was so crisp and sharp that I cut my hand on the edge. I did do a backwards score cut with the melamine. I am very pleased with this saw and the accuracy and quality of cut it leaves. This will definitely help my workflow and efficiency. BTW all cuts were made with the stock blade. 165mm 55 tooth with 1.6mm kerf. Makita has developed a new line of blades (1.6mm kerf) for their battery operated saws to increase run time. I know this is a Festool forum and I’m not taking anything away from the tsc55. I’m just pointing out my opinion of a great alternative.
