DVOM, what is the output voltage? This is a 2.0ah batt with around 1/2 charge.estley said:is there a more scientific way to test a battery other than switching it to another tool?
Lemwise said:Even if you tried different batteries that would be my first guess. You have to remember Li-Ion batteries have a limited life span, about 3 to 3,5 years from the moment they're produced.
Peter_C said:DVOM, what is the output voltage? This is a 2.0ah batt with around 1/2 charge.estley said:is there a more scientific way to test a battery other than switching it to another tool?
Alex said:Hm, my Li-ion batteries of 8 years old didn't get that memo - luckily.
Well that was an easy repair. Lots of people would have thrown it away...I get or buy broken stuff all the time and fix it. Usually it is an easy fix too.estley said:After inspecting the blades on the Impact driver that make contact with the battery, I found some residue of some sort, wiped it off with alcohol and now I'm back in business.
New brushless?? You won't be using your other one very often. I have two Makita 18volt brushless impacts and rarely use either. Instead my goto is a Milwaukee M12 brushless impact. LOLestley said:While this whole thing was going on, I did get a brand new brushless form another member here, so now I have two working impact drivers...
Thanks for all the help!!
Your tone suggests you know what your talking about, you don't. Two people have said now that their Makita batteries have lasted 8 years, that's twice the time you have stated but you still won't accept it. How long have your actual Makita batteries lasted if you own any? not the virtual ones you keep talking about.Lemwise said:Alex said:Hm, my Li-ion batteries of 8 years old didn't get that memo - luckily.
Assuming normal, every day, professional use, charging the batteries at least once a day and taking into account an average of 260 working days per year would mean your batteries have each been charged 2080 times. That my friend, is simply impossible for Li-Ion cells.
