cherron8776
- Nov 30, 2008
I'd like to attach a OF 1400 EQ router to a CT 22 E dust extractor using a 50 MM hose 4M long (starting at the CT 22) connected to a 36MM hose 3.5M long.
The support knowledgebase indicates that hoses longer than 23 feet should not be used. The above combination is 24.6 feet long. Will this be a problem?
Similar question: if I use a 27 MM hose attached to a TS 55 saw (instead of the 36 MM hose attached to the router), will this be a problem?
