MDF vs. “Sande” plywood.
Packard
Hudson Valley, NY
The local lumber yard stopped selling MDF a few years back.  Lowes stopped selling 1/2” MDF in full sheets.  It is only available in 1/4 sheets, resulting in huge amounts of scrap.
Home Depot sells full sheets for $50.00.
Full sheets of 1/2” “Sande” ply is $53.00 from Lowes.
I need these for center panels for cabinets (to be painted).
I am not finding much out there about Sande ply.  Is it flat?  Does it have an open grain like oak?  Will the grain telegraph through the paint.
I used to be able to go directly to paint on MDF and not worry about raising th “grain” on non machined surfaces. Now I have to wet and sand first, and again after the primer.
These are essentially the same cost.  So which will work better?
I bought some of the sande plywood from HD. I have yet to find a flat one lol
If you have a Menards or a professional grade plywood house, check into MDO plywood. It has a resin impregnated paper on the face that is paint-ready. It is very flat and very easy to work with. Usually fir core veneers. There are a couple companies that make it, but the biggest (or at least the one I'm most familiar with) is Roseburg out of Oregon.
I have used Sande ply a few times, usually for internal parts that can be glued via large joints.
Pros: light weight (especially compared to MDF), appears to sand up well if surface is unmarred--though even light marring is likely going to filled and sanded gently, as the wear layer is thin (I have not painted, so I can't say for certain you can hide the grain entirely, but I suspect yes).
Cons: Not flat, filled with voids, soft, will not hold screws reliably at all.
My general perception after working with it is it's an oddly powdery substance, although I am accustomed to baltic birch and thus was perhaps more taken aback than I should have been.
Since it's visible, my vote is MDF. Save yourself the time and headaches in finishing and getting to flat.
We've used Sandply for things like carts and shelves but it's a bit like paper mache`:cuts easily, light, relatively cheap, but weak. I wouldn't use it for cabinetry apart from maybe pedestal bases.
With sources for full-sheet MDF drying up, I envision a day when it will not be available at all.
For shaker cabinet center panels, the 2’ x 4’ quarter panels are absurdly wasteful.  I can get one cabinet door panel from each piece.  With a full sheet, I can get 9 or more cabinet doors.
So the 1/4 panels are not an acceptable format.
MDO panels are available but from a vendor 63 miles away—or 126 miles round trip.  With my van, that is almost 6 gallons of gas— or adding $19.50 per trip.  I don’t usually buy more than I need for a given project, so that would add up quickly.  Plus, MDO is fairly expensive.
ADDENDUM:  I see that Lowes will sell 1/2” MDO in full sheets for $88.00 per sheet.  It is special order, but no minimum is shown.  But that is still $38.00 per sheet more than MDF, which is generally fine for center field panels on Shaker doors.  For the time being I think I will stick with MDF.
Thanks for the replies.
I just put together an order, but Lowes charges $80.00 delivery fee, so that was cancelled.
I can pick it up, but that is 54 miles round trip. That pretty much kills either a morning or afternoon and costs about $18.00 in gas.
So, for as long as the MDF is available, I will continue to use it.
