jonny round boy
- Jul 21, 2007
Over the weekend, I cut/machined some 25mm thick poplar stock for a set of kitchen cabinet doors I'm making. This is the first set of doors I've made in this style since I discovered Festool...
After cutting to length, I cut 8mm domino slots in them (25mm deep in the ends of the rails, 28mm in the stiles) roughly centred in the stock (minus the 13mm depth of the groove this makes it perfectly sized for a 8x40 domino). Then I cut grooves in all the pieces, and cut the tenons on the ends of the rails HOWEVER the grooves & tenons are off centre as I wanted a 12mm panel depth. This has resulted in the following joints:
As you can see, the domino joint is half-way across the edge of the tenon/groove. I made a sample joint in this way a couple of weeks ago, and everything seemed fine with this arrangement, however I only assembled it dry. In retrospect, it's obvious that I should have placed the domino in the centre of the groove.
Now I've come to glue the doors up, I've found that they won't go together properly, as the domino is essentially pushing the joint sideways:
[attachimg=2]
So I've now got a full set of doors that I need to glue up, but I don't want the same thing happening on all of them. My question is, what do I do now? The way I figure it, I have four options:
Option 1 - Glue the joints up without fitting the dominoes, and rely solely on the tenon for strength (the tenons themselves are a nice snug fit);
Option 2 - plane/sand the dominos down so they're thin enough not to put any sideways pressure on the joint (which may totally negate any additional strength they would have contributed?);
Option 3 - re-cut all the mortices slightly lower/higher, again so that the domino doesn't exert any sideways pressure;
Option 4 - glue dominoes in all the mortices to plug the holes, re-machine the pieces, and re-cut the mortices centred on the groove (I really don't want to do this, it'd be very costly in terms of time and dominoes).
Option 1 would be the easiest, but I'm concerned about the strength of the joint (if I were to do this it would have been better not to bother with the dominoes!!!). The tenons are 72x12mm (3" x 1/2"), less approx 1/6th where the domino is). I'm unsure if this will give sufficient glue area.
I need to get these glued up in the next day or two, and I don't have the time or the stock to re-make them all. What should I do now?
[attachimg=2]
