mwbrewster
- Oct 14, 2017
Good morning all,
I saw Sedges Instagram post regarding the MFK 700 and being able to use it to trim edge banding around inside corners because of the way the base is shaped. I was wondering if anyone knows if you can use an edge beading bit with the MFK in this fashion to get the same results as you would with jack miters.
Hope so because I'm awful at making jack miters on my router table.
here's the post:https://www.instagram.com/p/BnRTBuBHAn0/?utm_source=ig_share_sheet&igshid=155y95614gkim
Thanks in advance
Matt
Thanks in advance
Matt
