MrToolJunkie
- Jul 6, 2009
Not sure if this has been posted, but I know that it has been discussed - I found a way to get everything into the Systainer for this router - you do have to unscrew the knob on the 0 degree base and lower the router to be flush with the vertical base, but it works! It is a tight fit - also, I put all my instructions under the insert in the bottom of the Systainer so I have them, but they are out of the way.
Here is a picture if anyone needs it...so far this has worked well. Not any other room, but at least all the bases are with the machine.
