tristan cochrane
- Nov 29, 2014
I recently took my MFT3 table top off the base and several days later I tried to reassemble it and it wont fit back in comfortably. does anyone know if it is a tight fit that needs to be knocked back in?; if you are supposed to slacken the frame and then tighten around the MDF top after (im worried that might throw the square sides out?)?; if I should cut or sand the MFT to fit back in again snuggly?
I am reluctant to force it incase i lose the accuracy and squareness I just paid so much for! Its about a month old. Any experience to share on fitting these tops would be welcome before I do it,
Thanks!
Thanks!
