Kodi Crescent said:Are you a hobbiest or a contractor? I'm a hobbiest. I got rid of my mitre saw and my table saw. Space was the issue, and I wasn't making anything on a production schedule. I haven't missed either, although I'd love to have both if I had the space. I'll replace the mitre saw once I make space in the garage and save up, but it isn't vital that I have it now that I have the MFT. Again, I'm not using my tools to make a living.
Tim Raleigh said:I have 2 CMS and the MFT and would not want to cut any molding or narrow stock (< 12") on anything but a CMS. If I couldn't afford a good CMS I would buy a miter box. I have cut miters on the MFT but those were multiple cuts for short corner shelves and the time it took to set up the MFT saved time in the end.
You can't get away without a table saw and the 4100 is a good option (I have one for site work) if you want to save space, but it is seriously underpowered for cutting 4/4 thicker hardwood like maple and the table size is extremely frustrating for cross cutting or dadoes.
The new 4100 is a good portable saw (the riving knife is good) and very adjustable but I wouldn't buy it with the mobile stand. Ya, it holds the saw and you can wheel it around but if you using it in your shop and you trying to save space the folded up stand with the saw on it takes up as much footprint as the saw does. The saw is light enough although awkward (lighter than an MFT) to lift in and out of a truck.
For added stability, and additional table real estate the Rousseau stand it gives you more space to work, particularly cutting wider stock. The design (mechanics) of the Rousseau fence is a bit weak. You can, as I have done also retro fit the Rousseau table with an after market fence like the Exaktor or Vega fences.
Tim
Dovetail65 said:You can't eliminate the miter without really sacrificing convenience. Either get a miter box or both. No way does an MFT replace the miter saw. Just like a guide rail saw does not eliminate the need for a table saw, IMHO.
blanning said:The other plan I had for a table saw was to get something like this:
http://www.grizzly.com/products/10-1-3-4-HP-Contractor-Style-Table-Saw-with-Riving-Knife/G0713
remove the legs and put it on this:
http://www.grizzly.com/products/Hydraulic-Mobile-Table-Cart-600-lbs-/H6240
Steel City has a similar saw with a worse fence. But I figured I could put a bies fence on that one. It would be twice the money over a bosch 4100. But it would be a much better saw.
Not sure how putting the saw on top of the mobile table cart saves space. Why wouldn't you just get the Grizzly mobile base? http://www.grizzly.com/products/Super-Heavy-Duty-Mobile-Base/G7315Z
The bies fence is nice.
Tim
Tim Raleigh said:Not sure how putting the saw on top of the mobile table cart saves space. Why wouldn't you just get the Grizzly mobile base? http://www.grizzly.com/products/Super-Heavy-Duty-Mobile-Base/G7315Z
Tim
Deke said:For all that money, you could buy your 17" Grizzly bandsaw (not the Powermatic 14"). [big grin]
I was making the squaring jig for my new MFT/3 from Jerry Work's manual this week. I figured out that I used approximately $16,000 worth of tools to make what amounts to a nice board with two holes in it. Woodworking - especially if the word "Festool" is involved, is expensive. [scared]blanning said:This is turning into an expensive proposition.Deke said:For all that money, you could buy your 17" Grizzly bandsaw (not the Powermatic 14"). [big grin]
TJ Cornish said:I was making the squaring jig for my new MFT/3 from Jerry Work's manual this week. I figured out that I used approximately $16,000 worth of tools to make what amounts to a nice board with two holes in it. Woodworking - especially if the word "Festool" is involved, is expensive. [scared]
To be fair, most of the $16,000 worth of tools were not Festool in this case.
Oh, I'm long past $16,000 - just couldn't figure out a way to use any more of them on this particular project. [big grin]Corwin said:TJ Cornish said:I was making the squaring jig for my new MFT/3 from Jerry Work's manual this week. I figured out that I used approximately $16,000 worth of tools to make what amounts to a nice board with two holes in it. Woodworking - especially if the word "Festool" is involved, is expensive. [scared]
Not to worry. It shouldn't be too hard to spend some more on Festools and before you now it $16,000 will be a distant memory. [wink]
