What happened to the folding extension for the MFT? Is it still available, and will it work with the MFT-3? I saw it on Brice Burrell's site, attached to an older MFT1080 I believe, and it looks like a handy add-on, but I can't find it online.
Bob, I fairly certain it was discontinued with the release of the MFT/3 tables. That's too bad because it is a real handy accessory. If you spend some time searching you'll probably be able to find a dealer that has one in stock.
BTW, you can modify it to work with the MFT/3 with a 1/2" shim.
I would guess the shim is to accommodate the difference in height from the MFT1080/800 to the MFT 3. Or at least a difference in height from the table top to the bar that the support rests on.
