B Brian H Member Joined Jul 23, 2013 Messages 35 May 27, 2014 #1 Do the portable extension arms that go with the cart work with the MFT? I'm new to Festool and putting together a setup to do crown. Thanks!
tbellemare Honorary Member Member Joined Nov 3, 2007 Messages 5,133 May 27, 2014 #2 If you mean the UG cart extensions, they work with the MFT/3 profiles. Tom
tjbnwi Member Joined May 12, 2008 Messages 7,126 May 27, 2014 #3 They work on the MFT, only hiccup is the thumb screw rubs the clamp groove. This makes it a little bit more difficult to set the tab and tighten the thumb screw. Tom Attachments IMG_2898.jpg 2.1 MB · Views: 548 IMG_2890.jpg 1.6 MB · Views: 501
B Brian H Member Joined Jul 23, 2013 Messages 35 May 29, 2014 #4 Thanks guys for the replies. And thank you for the pictures.
tbellemare Honorary Member Member Joined Nov 3, 2007 Messages 5,133 May 29, 2014 #6 Repeatability repeated... Tom
bkharman Member Joined Jul 1, 2013 Messages 2,072 May 29, 2014 #7 Be careful... I work for the Department of Redundancy Department.
tjbnwi Member Joined May 12, 2008 Messages 7,126 May 29, 2014 #8 GPowers said: I count 8 flag stops [big grin] Click to expand... Tom can verify this, that is less than half of the flag stops I own (and use). Each one had a very specific purpose, some for cuts, some for Domino mortices. If you look real closely, you may see the flat head bolts holding the fence in place. That MFT in 24" is 0.0000 out of square. Tom
Jesse Cloud Member Joined Jan 23, 2007 Messages 1,746 May 29, 2014 #9 bkharman said: Be careful... I work for the Department of Redundancy Department. Click to expand... What Department of DRD did you work in? Sorry, couldn't resist. I used to work in the gummint and that just sounded all too deja vu. [big grin]
