Crazyraceguy
- Oct 16, 2015
[member=76739]TomK_2[/member] you can rest assured that the OF1400 is far more is far more solid/tight than that old Craftsman unit (on its best day).....however, it may not be the best choice for use in that particular type of jig.
The reasoning behind that is the method of attachment for the copy rings (bushings). They have a quick and very simple "snap in" arrangement. It is great for popping the chip deflector and bushings on and off, in a tool-less manor, but there is a possibility of some slight movement. For most cases, were absolute precision is not the main goal, it's a worthy trade off.
When that need arises, the OF1010 is a better choice. There is an opposing thing going on there though. The copy rings, along with any other device that attaches to the base, are a bit more fiddly to install. They actually use 4 tiny screws, which allow for centering/adjustment. This is obviously slower, but the pay-back is precision.
The OF1010 is plenty of router for tasks like template work. It fills that space between a compact trim style router and it big brother OF1400 perfectly. It is big enough for most uses and still not be overly heavy (over-kill).
Don't get me wrong, the OF1400 is great, but it is a bit much for a lot of everyday things.
There you go......way more than you asked for [blink]
