Update for 19 November 2020.
I finally found the time to build the drawers for the end section. Each drawer is 883mm wide and 500mm deep and made from 15m plywood. The drawer fronts are made from 12mm plywood. Three of the drawers are 100mm tall, and the fourth drawer is 150mm tall. The drawer pulls are from the same vendor as the extrusion, and the drawers are recessed so the handles do not extend past the end of the frame.
Here are the contents of the first drawer. I used Kaizen foam for the lining of each drawer, and cut around each of the tools.
Contents of the second drawer. The Woodpeckers kit for the Domino came in a Systainer, and I didn't see any point in cutting Kazien for the contents, so I trimmed the Kaizen around the foam insert and declared victory.
Even with the shortcut of using the Woodpeckers insert, this drawer took the most time to prepare because of the angle clamps.
Contents of the third drawer. The longest guide rails for the TSO parallel guide kit are too big for the drawer, so they are on the catch tray.
The fourth drawer waiting on me to decide what to put in it.
The fence, FS 1400/2, and the long TSO guide rails fit on the catch tray when not in use.
My next project was to make the sliding trays for the Systainer cases. I am using 19mm plywood from scraps, and these will be mounted to the 400mm full extension slides along the sides of the workbench. Since I don't have a CNC machine (yet), I will use an 8mm cutter and the 11mm copy ring on the OF 1010 router
This is the routing template I used to make the 8mm deep recesses for the Systainer feet. The plywood cleats are glued to the 12mm MDF (more scrap) to ensure each of the 405x400mm trays are similar. Since I didn't want to be bothered with chiseling out all of the corners, I extended the router bit to ensure the corner of the Systainer feet had clearance.
The first test shelf is done, and the Systainer fits perfectly.
Twenty Systainer trays ready for sanding and painting. I doubt I will ever use all twenty, but since I had the template and a rhythm going, I used up most of my 19mm offcuts that have been gathering dust for a year. I made three trays for the VAC SYS Systainers. These are the original version and have a different feet layout.
