I have spent several days trying to get square cuts on my MFT3 using the TS 55 Req.
I am using the Woodpeckers 24 inch square for setup. The guide rail and the rear fence are absolutely square. I have checked every possible way over and over and there literally is not a paper width between the fence or guide rail.
However when I crosscut a 12 inch wide piece of ¾ inch plywood, the cut is off between a 64th and a 32nd.
I have confirmed that the fence is straight, that the left edge of the track is straight, and that the wood against the fence is straight.
What I can't know for certain it whether the left side of the guide rain is perfectly parallel with the track the saw rides on.
So, I'm thinking I should be doing better than this but I can't figure where I'm going wrong. [sad]
All suggestions are appreciated.
Thanks,
Dave Davis
Thanks,
Dave Davis
