neilc said:I have a Walko 3 and an MFT/3. Both are useful. A few points:
- walko holes are not on a square grid so you can't easily use Qwas dogs for 45 degree cuts like on an MFT
- the walko table top braces attach from each side and angle down. So creating a large table top that would span the two sides is possible but you'd need to accommodate how it attaches as it would need to slide as it locks into place. Doable but you would need the top to attach with slotted holes.
- walko is more portable than the MFT if that is a consideration at all.
- walko is a lot more money for equivalent space if that matters
- walko is looking for new distributors in the US so access to them and parts to build your own top could be limited. It appears from their walkousa.com site that it is no longer operational. But walko.nl mentions they are seeking a new distributor. It was FestoolJunkie but that relationship appears to be over.
Good luck. Both are good products
Neil
Really comes down to how you will use it
