I received my MFT/3 and TS 55 Friday and ran into some difficulty with the table setup. I probably am making a newby beginner mistake somewhere but I cannot slide the support brackets in the side rails to the stops. I can (with a lot difficulty) get the rail support brackets into the slot but it is extremely difficult to slide the support bracket along the rail to the stop. I was able to get both brackets to the stop using a lot of force but I am afraid the clip that attaches to the fram under the V rail will eventually dig into the aluminum side rail. I tried putting them (bracket plates) on the edge rails of the MFT to see if there was more space in the groove on the edge rails but it is just as difficult to slide on the edge rail. My supplier indicated he has not run across this before and is also researching the possible cause.
Anyone else ever have a problem sliding on the rail supports on their tables? If so, how did you fix it?
Thanks in advance
Bruce
Thanks in advance
Bruce
