Ken Milhinch
- May 5, 2007
I am an avid fan of the Kreg Pocket Hole system, so I recently bought a couple of their bench clamp plates and fitted them to my MFT. They work beautifully.
Ken, Sounds like a stealth gloat there... How about a review or at least your first impressions of the Jessem mortiser??Ken Milhinch said:Following on from that, I also decided to make use of the MFT for my newly arrived Jessem Slot Mortiser. I attached the mortiser to a piece of Cypress, and turned up a couple of 20mm dowels to act as locating pins on the MFT. Add two Festool clamps from below the table and it also works beautifully. ;D
Jesse Cloud said:Ken, Sounds like a stealth gloat there... How about a review or at least your first impressions of the Jessem mortiser??Ken Milhinch said:Following on from that, I also decided to make use of the MFT for my newly arrived Jessem Slot Mortiser. I attached the mortiser to a piece of Cypress, and turned up a couple of 20mm dowels to act as locating pins on the MFT. Add two Festool clamps from below the table and it also works beautifully. ;D
Dave Ronyak said:honeydokreg,
Thanks for posting how you are adding decorative features to the paneled doors.
Are you guiding the router freehand using the board behind it as a straightline reference?
Why did you not couple the router to a Festool Guide Rail and use stops to limit travel of the router?
Are you using a core box style bit?
No doubt the results will be very attractive.
Dave R.
Maybe not a stealth gloat, more of a driveby but anyway my first impressions are that it is great, and a quality piece of manufacture. John Lucas has done something of a review here. http://www.woodshopdemos.com/jess-zip-1.htm
