Hi all,
I am working on a new project (a small cabinet to hold my systainers) after getting the mft/ts55 set. I am having a problem getting cuts within 1mm accuracy. For example, I just cut a piece 450mm x 380mm. I needed a second piece exactly the same which I cut to about 438mmx370mm. All the other cuts (except for 1) I have made are out by approximately 1mm. I measure numerous time before cutting, and double check squareness. The last cut was using the rail on the mft, others were with the rail clamped to the board. I always clamp to the table and/or board. Marks are made with a pencil, magnifying glass, and an engineers square. The rail on the table is squared according to the standard method.
Part of the problem might be squareness, which I have been having a problem with - after I make the squaring cuts the opposite edges are out by 1mm. I fix it by aligning the rail flush with the narrow end and 1mm in from the edge on the wide end.
I would appreciate hearing what you think as I am seriously considering returning the set, and buying a table saw. Thanks.
Signed,
Very Frustrated.
Signed,
Very Frustrated.
