tjbnwi said:UG wings.
itchy said:tjbnwi said:UG wings.
How well do the UG wings support wider pieces like cabinet panels. Can they support the weight of off cuts without tipping over? I have been looking for a similar solution and this would be great if it worked as it's also a portable solution (which appeals to me).
tjbnwi said:itchy said:tjbnwi said:UG wings.
Depends on how you configure the wings.
itchy said:tjbnwi said:itchy said:tjbnwi said:UG wings.
Thanks Tom! Excellent illustration that seems like a very versatile setup that will allow you to handle narrow and wide pieces depending on the configuration and it is portable.
tjbnwi said:itchy said:tjbnwi said:itchy said:tjbnwi said:UG wings.
The locking knobs rub the square channel on the MFT as you tighten them. I got tired of this so I removed a little material on each knob.
Other advantage of the wings is they fit the Kapex and CMS.
