E
ericbuggeln
Guest
Per, you guys need to pitch a show to the History channel. They seem to be way into reality t.v. right now.
ericbuggeln said:Per, you guys need to pitch a show to the History channel. They seem to be way into reality t.v. right now.
JJ Wavra said:Per,
great review!
I saw the mft3 in the store a couple of times. I have a question for you, if you will let me indulge. The fence that goes perpendicular to the rail looks like it will go parallel with the rail is this correct (set to 90 deg.)? Also, if this is correct how easy would it be to slide back and forth in a parallel motion similar to a fence on a table saw? Obviously you would be limited in the size of the rip by the size of the guide rail but anything over and you set it up like a fence yes, no?
I hope this clear.
JJ
Jerry Work said:One thing to keep in mind is that the difference in height is exactly the deck height on the Kapex so if you have both tables you have instant, fully flexible in-out feed support without having to resort to additional stands or wings.
Per Swenson said:DO NOT DO THIS
I in no way shape or form recommend you do this.
But, If you do, make sure your vac is empty and sucking.
Do not try it with out the vac.
Make sure your riving knife is installed if you are using a AT 55 and in good working order.
Make sure you are not ascairt. If you are afraid, that should tell you something.
Now, you can mass produce pieces to the right of the blade using the fence as a stop.
Faster then any table saw, because you are not pulling the sheet back, just sliding it to the right.
Once again, If you think this is a bad Idea, don't do it.
If you have never worked a little outside of convention, don't do it.
But here is what I am talkin about.
[attachimg=#]
Per
nickao said:Michael, I have a vac clamp that is connected to the mft. It is attached to the bottom and sucks through one or more holes depending on how big a piece I need to hold,. I use it for when I pattern route to a template.
I will put up a picture, better yet a video next week some time.
Nick
nickao said:I line up the gasketed plate under one or more holes from under the mft and it holds really well. The vac pressure will actually hold the piece on top of the table and the gasketed piece on the bottom. If you do not want to permanently attach the gasketed piece on the the bottom it will fall off when the pressure is released. Its all set up with a foot peddle.
Nick
nickao said:I just use little metal Z brackets which allows me too slide the unit back and forth across different hole layouts. And prevents it from falling off.
Nick
