MFTC portable workshop
What's the Festool part number for that lid holder-opener in the first picture?
That will be the new Domino Sipo, 3 x 250, partnumber = 494874. Unfortunately only available in Drachten, the Netherlands  [blink]
The reason why the lid will not open completely... I ordered the wrong size drawer runners [eek] 300mm (approx 11.75 inc) in stead of the required 350mm (approx 13.75 inch). For this "prototype" I'll leave it like this...
Mftc from Denver Colorado almost finished![attachthumb=#][attachimg=#]
put my laser cutter to work for cutting out the 1/2'' ply. also included the small work top and quick removable top and handle.
Incredible Avery!
I just bought Tim's plans a day or so ago.  I'm going to need to modify them because half of my gear is in Dewalt T-Stacks but I can't wait to get going on two of these.
Nice job Alonzo and Averey!  Hey Averey you have a laser cutter? Id like to see that in action. Looks really good. I just finised mine will post soon.
[attachimg=#]
Some Notes: Most of you would probably not make these mistakes, but here are some suggestions. Tims Plans are dead on. Don't be afraid to cut all the pieces before assembly as long as you are not changing sizes of any of the parts. And you have purchased all of your hardware and don't need minor adjustments for hardware that is not the same as the plans. (wheel size, drawer slides, adjustable feet...)
Paint the add on pieces first.  I painted the black parts in place. Big mistake, pain in the ass. But I was so excited to get this cart together.
I had a hard time with the feet. I used a leveling foot insert, then screwed the foot into it. The insert is 34.9 mm (1 ⅜") round. It was the only one I could find and I had built the legs already. I had to sand the plastic insert down to fit it. I probably would have built the legs a couple of mm larger if I had the part first. I got mine from grainger.  By the way, this would be an example of changing the size of something and having a fit problem down the road. Tims tolerances are pretty tight, if I made the legs thicker, they would probably rub when folding the cart up.
The feet under the cabinet of the cart are a must, the cart will easily tip when in folded position without them.
I used carriage bolts instead of a wheel axel. I couldn't figure out how the wheel stays on the axel. Lol. (i couldn't seem to locate the locking ring.) The only problem I had, was I drilled the deep hole for one of the wheel carriage bolts  on a slight angle and now one wheel is not completely straight. This does not cause an operating problem, just annoys me visually.
I no longer have a shop, I built this in my laundry room in a space about 11ft x 6ft. I used my track saw for everything. For those of you with a real shop, this should go together pretty quickly. Took me about 2 weeks of spare time, in between jobs. I built the top first, and then used it on horses to build the rest of the parts.
I used Lee Valley drawer slides: part # 02K4835 Pr 350mm(14") Full Ext Touch Open Slides  4 @ 17.60ea 70.40 TL.
I only own a Festool FS 75, OF 1400 router, and Midi dust extractor. I will reconfigure the drawer system as I acquire more Festool.
Thank you Tim, your work is amazing, I love my MFTC! I wonder if you know how many confirmed MFTC have been built?
Jim Megna
megnabuilding.net
One more thing. I learned how to work in metric from this project. Why Oh why are we still using imperial measurements in the US. Metric is a no brainer.
Also: I just installed my t track got it from Incra
Metric is awesome!
From a european perspective I am having a very hard time understanding why you still use the imperial system. ;)
On the other hand, it seems that noone appreciates plywood here in Sweden everyone use MDF. I would really like to have the kind of supply that you have of plywood over there...
On topic: I have also purchased Tims plans but have not yet been able to build one. The plans are really great though and the fact that you get the sketchup drawings as well makes it possible to make adjustments.
There are a lot of nice builds in this thread, really nice of you to share!
LOL! From an American perspective I am having a very hard time understanding why we still use the imperial system also.  [big grin]
Improvements on the MFTC-XL.
Moving forward at slow pace... Eventually we'll get there...  [embarassed]
...and the drilled top is in place as well...
I've switched to metric in the shop. At my age , it's a lot easier than imperial math...
Finally got around to buying the plans. Thanks Tim, and all those who shared part #'s ect!
may be a bit before it gets done but this way I can ponder  [thumbs up]
I just bought a set of plans!  I can't wait to build the first of many.  I'll send photo once I'm done.  Great job Tim.
Bought the plans. Not sure when I will be able to do this. Someone was talking about stairs in an earlier post. Would it be possible/feasible to switch the wheel design to a 3-wheel rotating layout on both sides which would enable you to "glide" up stairs? Gotta think about that. Malte
It must be possible without major if any adaptations besides the position of the axle, always having 4 wheels on the ground might even add to the stability.
