MFTC portable workshop
Hey, I'm wondering if there's a US parts list yet...I've been digging everywhere and I'm trying to put together my own before I begin the build.
So far I've got
T track for ptreeusa.com #1018
Slides leevalley.com touch open slides
Feet ??? I've found one camar distributor petermeier.com but they don't carry the 323 series. They carry the 343 and 345 series but I can't seem to find the diameter for either of them.
Wheels????
Maybe someone can fill in the blanks
@elimelech12,
the wheels shouldn't be a problem. In worst case you can use the orignal festool wheels for the ct vacs from frestool ekat.
The Camar legs of series 323 are also a problem in germany. A request to the german camar division is still unanswered. As an alternative I'm focussing M8 height adjustable feet with corresponding stop nuts (this is the goolgle translation for the german Schlagmutter).
I just bought some 8" wheels from ACE hardware.  However, I don't plan to use my MFTC that much off-site, so weight isn't that much of a concern.  You might try Grainger Supply
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=8%22+Wheels&op=search&Ntt=8%22+Wheels&N=0&GlobalSearch=true&sst=subsetfor wheels
It might be best to call them and ask for help finding the lightest 8" wheel - they have too many choices!
I found that the Peach Tree T-track is deeper and wider than the MFTC plans call for.  Therefore I would use a wood/metal glue when installing the T-track to provide additional surface area for gluing.
threedots said:
@elimelech12,
I was able to find a camar dealer here in the US but I believe they only sell in bulk 345-10-02 are the ones I wanted to use and they are all 28mm OD.
Also has anyone tried building the carcass out of 12mm mdf? I know there was a question about the availability of it in the US. If any one is in NY/NJ, Larkin Lumber carries Ultralite MDF in metric.
Thats a good point....hmmm... :-\...what are you using?
I did use the Peachtree T-track but routed the 3/4" rail first for the added depth and then glued the 1/2" outer piece in two pieces.  I did not use wood/metal glue to attach the rail but just wished I had afterwards.  Seems pretty solid but I haven't attached the top yet.  Just finished drilling holes.  I cut it oversize and will trim it to fit the frame opening.
You can find the Camar legs at cabinet parts.com.
I plan to try something different from Lee Valley:  http://www.leevalley.com/US/hardware/Page.aspx?p=70815&cat=3,40993,41283
Haven't received them yet, if they don't work I plan to use some standard levelers that I purchased from Woodcraft.
I actually got in contact with the guys at Peter Meier and although they sell bulk they said they would send me 8...I'm gonna go with the camar 443-10-p2...they are $1.60 a piece
Sorry for not being active lately, the harvest has begun so i spend most of my time driving a combine!
elimelech12 said:
Does anyone think building the carcass out of 12mm Mdf would present problem?
I have both an imperial and metric version of the MFTC plans,
In the imperial plans i adapted everything to use imperial sized sheet goods, so instead of 12mm you have 12.7mm, so you can use imperial materials.
if however you got the metric plan for some reason then just mail me and i can send you the imperial version (the imperial version is still expressed in metric numbers, just adapted to imperial sheet thickness)
[attachthumb=#][attachmini=#][attachurl=#]The push push locks I can not find then I looked every where I went to the Home Depot to get some push lock but it did not hold the drawer in
So my carcass has been done for a while but it's a side project as I don't have the time to fully dedicate to it. I made the legs out of 2x4 but I'm not to happy with them. I also built the carcass out of Mdf and I don't think it will be able to handle the drawers or constant moving to and fro. Also the T-track from peachtree is a little to thick so i'll most likely redo the top frame and use 3/4 all around. Here's what I've built so far.
Looks nice to me, i wouldn't worry about mdf not holding the drawers. I didn't use it because of the weight, but it is more resistant than you initially think.
Sometimes i trash damaged or surplus MDF carcass type assemblies which are just nailed and glued together, and often smashing them on the concrete doesn't do any damage. I need to take out a hammer.
Good luck with the continuation!
Tim,
you might get a kick out of this.  A little off topic, but you are familiar with farm equipment.
When i was in HS, i was working on a small dairy farm.  It was owned by a New York City newspaper guy who was using the farm as a tax write off.  i had lived on a real working farm for several years before that, so i knew a little about poor operating procedures when i saw them.  This owner had bought a one row seeder for sowing the corn crop.  the farm was very hilly and he seemed to have directed the manager to plant the corn on the hilliest piece of ground on the farm.  He later bought a harvester machine that cut and bundled the corn to be loaded onto wagons and hauled to the silo.
now, with very hilly ground that was loaded with stones of all sizes (Connecticut ground seems to grow new stones every year.  a never ending chore of removing same), and a planter capable of only one very crooked row at a time, you, i am sure, can picture the fallacy of using an 4 row harvester to cut the corn.
Need I say more? [laughing]
Tinker
A massive Thank you to Timtool for this.  Ive been testing my beloved MFTC for the past couple of weeks now and love it!
[attachthumb=#]
I made a couple of small changes to mine, I don't own a domino (yet) so bored 20mm holes in the legs with a router to allow me to use the parf dogs as supports.  This meant changing the dimensions of the rails at the drawer end to match the width of the folding legs.
[attachthumb=#]
I could not locate any decent adjustable feet so opted for M8 feet on pronged tee nuts.  I wanted a solid surface for the extension tables so used the same method for the top of the main MFTC and extended the legs to full length (I keep a selection of plastic shims in the drawer in case I need to level it up).  I got the T Tracks and toggle bolts (used to connect the extension tables) from  http://www.rutlands.co.uk/
[attachthumb=#]
The drawer slides have a built in 'push to open' mechanism and are made by a firm called 'GTV'.  I purchased them (along with the wheels and feet) from Ebay.
[attachthumb=#]
Thanks again to Tim.
