I'm using the OF-1400, but I'm sure this applies to any plunge router:
How is it possible to make micro adjustments to depth of cut with a dovetail bit?
In order to keep the router from springing back up and damaging the bit against the bushing, the large knob must always be locked, and this prevents any micro adjust to the cut height.
Am I forced to make a test cut on a board, and then measure that cut depth to see if it matches the board thickness?
