Micro-Adjusting the CMS Fence or any other stop
Limey556
I thought I would share this simple technique for micro-adjusting (within -0.001) the fence on CMS it also applies to any other stop you might have.
I use this dial indicator method when needing to sneak up on a dimension where a close fit is required.
[attachimg=#]
These dial indicators were $19 each on amazon
[attachimg=#]
I used the Crown Stops from the Kapex to help clamp them in-place. Nice how all the Festool stuff works together !
[attachimg=#]
I needed to machine this slot as a tight fit. Simple to adjust when you can work to 0.001 !
[attachimg=#]
Works just as well on the MFT stops although I admit it's less likely to be needed here still nice to have the option
[attachimg=#]
Same thing for the Kapex
[attachimg=#]
Works really well for adjusting the Table saw fence these dial indicators have a 1 inch travel more than enough to dial it in.
Terry
