Milton air fittings deal on Amazon
rvieceli
Carbondale Illinois
For reasons that I can’t quite understand, Amazon has been running some unbelievable prices on some quality 1/4 inch NPT Milton air fittings.
The links below are for packs of 10. The first two are for the plugs both male and female HighFlo V style fittings. The other two are for couplers the plugs fit into. The couplers are universal type.
If you are converting a hose with ¼ inch NPT fittings you will typically need female versions of the plug and the coupler. If you are adding a coupler to a drop (black iron or rapid air type fitting) or a plug to a tool you will typically need a male version.
The plugs are usually in stock, the couplers go in and out of stock on a frequent basis so if you want some keep checking Amazon.
Ron
Milton Industries 760 1/4" MNPT HIGHFLOWPRO™ V-Style/European Interchange Brass Air Plug Fitting
Pack of 10 for $3.69
https://www.amazon.com/dp/B003V5RPN...10&amp=&crid=1WJ2VOVNGKTF&amp=&sprefix=milton+760
Milton 761 1/4" FNPT HIGHFLOWPRO V-Style/European Interchange Brass Air Plug Fitting
Pack of 10 for $1.48
https://www.amazon.com/gp/product/B003V5TUP2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
These are universal couplers: Accepts all major interchanges: Industrial (M-Style), High Flow (V-Style), Automotive (T-style), ARO (A-Style) and Lincoln (L-style)
Milton 743 Universal Coupler, 1/4" body; 1/4" FNPT
Pack of 10 for $14.18
https://www.amazon.com/Milton-Unive...ref=sr_1_2?crid=3JY5AL0F0OGR5&keywords=milton+743&qid=1681316291&s=hi&sprefix=milton+743%2Ctools%2C102&sr=1-2
Milton 744 Universal Coupler, 1/4" body; 1/4" MNPT
https://www.amazon.com/Milton-Unive.../ref=sr_1_1?crid=LQZLDYZ387MH&keywords=milton+744&qid=1681316350&s=hi&sprefix=milton+744%2Ctools%2C94&sr=1-1
Cheese, I believe you are correct but I don't have a vac sys to check them on.  [eek]
I believe that the universal couplers result in a slight loss in air flow on the V style plugs over actual V style coupler but I think the loss is less than 10%
Ron
Even better, the Male HIGHFLOW fittings were $1.48/10 until a few weeks ago, same as the Female, when they "jumped" to $3.69.
They've been priced that low since April, 2021.  [eek]
I've been looking to add some additional quick disconnects to my Vac Sys setup, so I may just need to grab a 10-pack and see what's what.
Received my Milton connectors yesterday...thanks Ron...and they do indeed fit the Vac Sys. The 2nd photo is the Festool foot valve connections.
[attachimg=2]
[attachimg=3]
Yup they go in and out of stock frequently.
Currently the Female couples 743 are in stock and on sale for $10.  [eek] [eek]
But the males are out
Ron
