I have been brainstorming ways to make the dust collection at the miter station more efficient (and less maintenance).
The current set up has the Kapex deck the same height as the infeed/outfeed. The primary dust collection comes from underneath from a network of 6" piping. The last couple of feet under the saw are 6" flex duct attached to the underside of the countertop the Kapex sits on. Around the Kapex is a "shroud" that prevents dust from escaping above and to the sides of the saw. There is a small shop vac connected to the Kapex dust port to collect at the cut which is activated by an automatic switch.
A couple of recent changes to the saw are the addition of the Colliflower Cube and the Colliflower ZCI, both of which I have really enjoyed using. The Cube works well to support the workpiece behind the blade, but does interfere a bit with the airflow.
Changing the collection bag in the shop vac is a pain. It lives in a small cabinet next to the saw. Due to this space restriction, the shop vac itself is small and fills up fairly frequently.
My thought is to somehow connect a small hose off of the 6" while maintaining the 6" up to the saw. There is, of course, no off the shelf 6" connector with a 2 or 2.5" wye, at least that I can find online. Has anyone tried something similar or have any thoughts?
Thanks!
Thanks!
