Tayler_mann said:My mentor will only build cabinets with mitered cases. In his words, "they look real good that way." He's been building cabinets since the late 70's and I'd say he's gotten good at it. He swears up and down by biscuits because they have a fudge factor.
I on the other hand will do it with dominos regularly. I use 5 mm dominos and place a domino every 80-100mm depending on the size of the case. It works well but I like to only do two tight dominos and the rest loose. For some reason the last few times I tried all tight my case was off a 1/2 mm in lining up and it frustrated me when doing my doors. Good thing I have a track saw and went around all 4 sides to straighten it up again.
Mitered cabinets really do make it look like a custom cabinet build and not prefabs from Home Depot or lowes. If you also miter the face frame into the case with a compounded corner it looks REALLY nice. I haven't gotten there myself but my mentor has done a kitchen full and it made the cases looks carved out of solid hunks of wood. Small details are what matter.
jeep jake said:Hey guys starting a couple cabinet projects and I want to do miter the carcass corners any ideas I own a domino XL and was thinking about ordering the Seneca adapter or buying/borrowing a biscuit cutter. Is there a good practice way of doing it?
Holmz said:If you could borrow a Zeta-P2 and use Clampex then that would be one way to go.
Brice Burrell said:If I could borrow a space shuttle I could go to space... [blink]
jeep jake said:3/4" plywood. Maybe mdf, I have heard lock miters don't work very well with plywood I am also worried about routing them. I have a feeling it's going to be tough. I was thinking about picking up a cms, do you guys think there would be a issue using it for this. My concern is running the vertical carcass side, vertical through the router.
Hurricane Whisperer said:Tayler_mann said:My mentor will only build cabinets with mitered cases. In his words, "they look real good that way." He's been building cabinets since the late 70's and I'd say he's gotten good at it. He swears up and down by biscuits because they have a fudge factor.
Interesting. Got any Pics? I can see how mitered cabinet boxes and face frames would be very showy on something like a credenza or a side table, but I'm having a hard time seeing how a mitered box would be visible in a face framed kitchen cabinet that gets a countertop on it.
Brice Burrell said:Holmz said:If you could borrow a Zeta-P2 and use Clampex then that would be one way to go.
