Mobile MFT and Flexible Boom Arm
mohrab
I figured it was about time I contributed to this forum having benefited from many of the ideas posted by members.
I have small ?L? shaped workshop in my barn which is used for many things other than woodworking ? therefore have limited space.  I initially suspended by hose/cord from the ceiling but kept moving my MFT ? as a result did a quick & dirty fix to mobilize my MFT and enclosed the pulley system in a boom arm.  I also raise the MFT to match the height of the MFT/3 which I prefer.
The boom arm looks huge but that is because it houses a weight and pulley system to allow my vacuum hose and power cord to be pulled into a totally horizontal position thereby maximizing it?s reach.
The boom arm is made out of 2? PVC and has a 2? trailer hitch ball suspended inside as a weight.  The trailer ball is supported by small pulleys located at each bend of the boom arm.  It seemed to be about the right weight to allow the hose to be pulled out and then retracted to hold the hose out of the way.  Here is a close-up of the boom arm.
[attachimg=2]
My MFT 1080 is simply mounted on a 1-1/4? piece of plywood trimmed with 2x4?s to accommodate the leg spread and keep and table and CT33 in place on the platform.  I used (4) locking swivel casters from Hartville Tool to provide mobility.  I find it very stationary in use ? often only locking two of the casters.  I wanted to build a cabinet under the MFT but since doing this have higher priorities for the time being.
I use my TS 55 to cut down sheet goods to size w/o removing the saw from my MFT set-up.  My cutting table is Josh Finn?s (Fine Woodworking #202) Workbench solution which I adapted by adding a Kreg Fence.
[attachimg=3]
If necessary I can easily move the MFT closer but often find I don?t need to move it all ? the hose and cord reach fine!  Hope this adds from value to the forum?.
To compress the image:
Right click on photo.
Choose 'Open with' Paint.
Click ' Image'.
Click 'Resize/Skew'.
Change horizontal & vertical to 25%.
Save new file.
Done.
mohrab,
Welcome to the forum.
Yes, post photos!
You can do what DustyLeigh suggested.  Also, we have a section of the forum dedicated to discussions about handling photos, with lots of options and instructions.  You can post a new question there if you wish.  Here's a link ----> FOG Photo Discussions.
Remember, you can edit your original post to include a photo.
Again, welcome!
Thanks,
Matthew
mohrab, I really like your mobile base.  It is simple, yet functional, and allows for easy removal of the MFS when necessary.  For my use, it would be the best of both worlds.  The boom arm is also very clever, simple and functional.  Excellent!
Mohrab,  Nice digs!  I especially like your sheet stock rack and your shorts rack in the corner.  Good use of unusable space, if that makes sense.  :-\
Mohrab,
  Nice mobile base! I keep wanting to make a rolling cabinet too but haven't found the time. Perhaps I could manage one of these. Thanks for the pics.
Mike
I like the hanger for the Woodpecker square too! ;D
