DynaGlide
- May 16, 2017
Now that the table saw setup has been worked out: https://www.festoolownersgroup.com/other-tools-accessories/upgraded-my-dw745-(part-2)/ it's time to continue on my theme of shop upgrades while my shop is occupied by Christmas elves (read: turned into a gift wrapping station against my wishes).
This one has bothered me for a good long while. .several years now. I just couldn't figure out a good way to fix it without spending lots of money until a couple things just clicked in my head. I own a DeWALT DWS780/782 miter saw. I love it. It's mounted to one of those Ridgid rolling miter saw carts you see at Home Depot for $99 every year around Black Friday. What I don't love about the saw is that I can't get repeatable accuracy out of it unless I unmount it, move it to my MFT/3 benches and set one up, like so:
So I got to thinking about it. .then gave up, thought some more, gave up again and a light bulb hit this past week. Why not mount the saw to an "MFT" table on the Ridgid cart, then build up from there?
I took a floating MFT top I made as one of my first Festool projects, took some measurements and did some test cuts and secured a MDF spacer to one end to level it with the bed of the miter saw. The other end gets held up by the Ridgid material support. Once its set I don't have to fiddle with the height. Then to secure the top to the base I use a clamping element. Whole thing takes 2min to setup. The extended fence is a spare MFT/3 fence with fence dogs. Drops in and out in seconds. If you don't have or want to use a MFT/3 fence then you could use [member=61691]TSO_Products[/member] material stops and measure your first cut, set a stop, and away you go. The tape adhered to my spare fence isn't calibrated but I think I will do that moving forward so I never have to measure again.
Lots of possibilities:
The array of holes on the top table are 20mm on 96mm centers. You could use it like an MW1000 table if you so desired with some dogs for square cuts, clamping, sanding, etc.
I hope this helps,
Matt
I hope this helps,
Matt
