nickao
- Feb 24, 2008
125.00 plus 12.00 Shipping to the lower 48. 100% Money back return policy.
Brand New in a case never used .
Cuts out the trim in door ways where it hits the floor to give you the height to slip in new hardwood or tile.
Mortensen Industries 19514 Power Door jamb Saw
I have never used nor tried this type of saw. I am told it vibrates a little, but for certain cuts it is great This would back up your Crain saw nicely because it cuts on both sides of the blade. This will not replace a 400.00 Crain jamb saw, but is great for someone doing a few small jobs or in addition to the Crain saw. I do know the blade is excellent because I have and use the hand version of this saw. Other than that I do not know much about it.
Technical Details
* Stop cutting door jams by hand
* easy to use
* For installing Carpet, Vinyl, Hardwood/ Laminate etc
* Cuts without splintering
Product Description
Floor covering professionals as well as do-it-yourselfers, will appreciate this value addition to their tool kit. Whether installing tile, carpet, vinyl or hardwood/laminate floors, the Power Doorjamb Saw will eliminate the laborious effort of cutting doorjambs by hand or with the expense and mess that comes with using the old circular doorjamb saw. Can be used in most flush applications as well, such as cutting off wood or plastic pieces sticking out of floors or walls.
Technical Details
* easy to use
Product Description
