Slappy
- Aug 21, 2013
I asked this question on a thread of another person but it's best If I start a thread here than Hi-Jack a thread .
anyone who has a Incra LS can you Plz measure the area of the bottom mounting of the positioner ? lenght & width from the furthest outside edges .
(this would be the area that makes contact with a router table ,Table saw , the LS has a dual slot mount that also has pass thru bolt holes for direct mounting as well) from the photo is looks to be about 6" X 10" , the Incra site & also the LS manual doesn't give these exact dimensions (i'm not looking at the distance between the bolt holes but the actual size of the mounting area )
I'm looking at mounting the Incra LS to my soon to be built Extended Ho'made MFT table
I want to mount the LS on a 1/4" AL plate that will cover 2 series of pairs of the MFT spaced holes & then use 4 Qwas mini rail dogs bolted the the AL plate & then the LS bolted up from the AL plate using counter sunk screw bolts so that the AL mounting plate sits flat on the table surface .
this way I can drop the Incra LS directly onto my table & have it square the 20mm holes
I am looking at AL plate stock & sometimes the 8020 Ebay store has AL plate 2nds that are really inexpensive .
If I see a AL plate 2nd that would work for the size I need I could snap it up now & have it in hand when I get my LS soon !
