Multi Blades Kapex brackets and Festool carry strap
Monju123
Has anyone come up with a method for attaching the Festool carry strap to Kapex Extension wings with Multi Blade brackets attached to them?
I second this request.
I'm currently using to heavy duty Velcro straps to cinch and hold the wings together for transport. Down side is they don't protect the ends...
Which wings do you refer to?
The KA-UG-KS 120-R/L pack comes with end protectors and a carry strap:
Since the end protectors are made of plastic (and only held together by the strap, so additional length should not be an issue) it should be possible to use a Dremel to make additional room in them so the MultiBlade brackets fit...
Lewis Carpentry said:
What is the advantage of the multi blade brackets over the standard ug wing connection?
The Festool Crown Stops will not work in conjunction with the Wings, so using the Festool products you have to choose either the Crown Stops OR the Wings. The MultiBlades bracket includes a T-track that works like the Crown Stops.
