My cnc'd bench top
I made this from plain MDF. Its my very first CNC project.
Cool nice one .do you have a CNC in your shop?
You had better get the iron back in the house before the wife finds out
Big bench.
You want to reduce the radias on those finger joints.
Also the edge doesn't look sharp did you use a upwards cutter?
Best use a compression cutter clean cut both sides.
Here is a close up shot of a box I made using finger joint method using a 9.5mm compression cutter only.
That's 18mm birch in one pass
I used a 12.7mm compression cutter that why I couldn't reduce the radius. Its the only straight cutter we have for MDF at the min :-(
I like a big bench for assembly and having a place to set tools onto while I'm at it
As your first project though pretty good.
I didn't dare go into full sheets on my first projects I played with off cuts.
This was my first project on my Cnc
[attachthumb=1]
No unfortunaly I don't have a CNC in my shop. Its in a guys workshop that I sub most of my work off. I'm going to be making the shop fits for him from now on and running the CNC as well.
Thanks JMB. I draw everything in AutoCAD and import it into the vcarve software. Its a nice software to use and relativly easy to figure out as well. Iv never used a CNC before so its going good so far
I have a 12mm cutter but never us it to big I think best with 9.45 big enough to take the force small enough for most jobs.
I'm planning on building one this week. Picked up a pair of the dewalt saw horses today to build it on. Not sure if I will cut all the holes or just do 3 for now to use for butting the rail up to.
Got my 20mm cutter through today , made up a jig and routed away. I doubt it's perfect but it's the best I could do. Just used a 30mm forstner in pillar drill to make the jig. Then drilled 2 x 20mm holes to drop dogs into the previous set of holes to line up for the next set.
I was surprised how often I had to clean the cutter, burnt a couple of holes but all in all it came out well.
galwaydude18 said:
Nice one joiner1970. What are the yellow things under your router?
Packers the guide Bush on the of 1010 sticks out 7mm and the piece of scrap I used for the jig is 6mm so had to slip 1mm packers under the router.
How did we manage before plastic packers were invented, so many uses. My wife tells everyone that our house is built out of them, it's a victorian school we converted and I got through packets of the things.
Doug
Another pic with a 50mm edging added to stiffen it up , just gotta give the edge a sand with my rotex when the  glue has had time to set.
Sorry to throw the thread but what's happening with FOG?
This is how it's showing on my screen
