OK, so I've installed my concrete counter tops. My first attempt was a failure, but I seem to have learned a fair amount from my first try, and come out looking at least OK on my second try! I still have some shimming to do, and then I need to caulk everything. Once done with that, I'll use some hand diamond pads to smooth the seam in the middle, and call it a day:
http://b.m.hart1.googlepages.com/home
(lotsa pics, and all far too high resolution to be hosted here)
I used the TS 55, and RO 150 FEQ primarily for this project. I used the saw to rip cut the mold pieces, including the mitered pieces for the sink knockout. I used the sander to do all of the polishing work with the exception of a rough grinding on the tops of the pieces. I used it to do the rough grinding on the edges (with Saphir 24 abrasives) then used a 5" dry 100 grit diamond pad. Even though it was a bit too small, it worked quite well. Once done with the diamond pad, I used the Platin 500 through 4000 grits to polish the concrete. One thing I need to do is to buy a Festool drill if I ever do this again. Switching between bits would have saved me at least an hour, probably two on my last mold.
Oddly enough, I didn't really use any of the Festool tools on my first attempt, other than to polish a bit. However, on the second attempt, the accuracy of the saw and the rail system helped me a TON. I think the difference in results can be attributed to me getting over the hump a bit on the learning curve, but a lot to the better accuracy of the tools I was using the second time around.
Various other tools were used, such as a corded Dewalt drill with a plaster mixing paddle to do a quick "blend" to even out the concrete dye before I mixed each 80 pound bag basically by hand in 19 gallon buckets. I also used the same drill to drill countersinks and pilot holes for screws every three inches. I vibrated the concrete by vigorously shaking the table back and forth, and once both molds were full, by pounding on it with a 16 ounce rubber mallot.
I know that the RO 150 FEQ was not designed nor intended to grind / polish concrete, but it held up fairly well. It had issues with diamond pads, and the vertical surfaces, but the random orbit was HUGE in turning out a nice finish. There are certainly portions where I could have / should have done a better (as in, more even) job, but I liked the look, so I called it 'good enough'.
The beauty of the Festool products was the cleanup portion. Now, this isn't the traditional "clean up a bunch of wood chips". Using the RO 150 FEQ instead of a wet polisher meant I didn't have to stand around with water splashing everywhere, hoping to whatever God you all may wish to pray to that the GFCI worked as it was supposed to if something went wrong. So, my basement is not a freaking swamp of concrete-muddy water for days. Sure, I track in concrete dust, but the house is trashed anyway, dust is no big deal, mud still gets the evil eye in a major way.
