Michael Garrett said:
Joseph C said:
You could order the all the lid parts via Festool if you look up the part#s via EKAT. All together, it runs about $35
You could also just order a new Tanos systainer from Lee Valley for $80, but then it won't it won't have a FESTOOL logo or a bright green latch [scared]
The lids are easy enough to swap out; I took the SYS-2 w attic from Lee Valley and swapped the lid onto a SYS-3 for my drills.
Do you have the part # for the drill inserts that go in the lid?
Since I recently went through this for myself, I just HAPPEN to have a list handy:
Bit assortment
BITS + BHS 65 CE TL 24x
Suitable for tool types:
for SYS TL with lid compartment
Items Included
• 2 standard bits: PH 1, PH 2, PH 3, PZ 1, PZ 2, PZ 3, TX 10, TX 15, TX 20, TX 25, TX 30, TX 40
• 1 CENTROTEC quick-change bit holder: BHS 65 CE
Description:
• Bits range
• CENTROTEC fixture
• Insert ideal for Systainer T-LOC
• Swivel-mounted and moveable modules
• 24-piece
Order number: 769094
£34.62
Bits
CENTROTEC BITS CE SET TL 6X
Items Included
• 6 CENTROTEC bits: PZ 2-100 CE, PZ 3-100 CE, TX 15-100 CE, TX 20-100 CE, TX 25-100 CE, TX 30-100 CE
Description:
• Bits range
• CENTROTEC fixture
Technical data
qty. in pack 6 piece(s)
Order number: 769095
£39.06
Drill bit
DB WOOD CE SET TL 6x
Items Included
• 6 CENTROTEC wood twist drills
Description:
• Wood drills set
• CENTROTEC fixture
Technical data
Diameter 4, 2x5, 6, 8, 10 mm
Order number: 769093
£53.52
Don't trust my pricing - it came from the Festool UK website but it's been a few months...
