Need Help Choosing a Compact Table Saw
In my case, only two hole sizes.  The top and front holes are the same size and fit the Rockler hose I referenced above.
In my case I measured with a Caliper and cut the holes with a CNC.  That let me do a press fit for easy removal of the box.
The over blade collection definitely helps with dust.  But you do need to plan for hose management of you are doing a wide rip on sheet goods so keep that in mind before you cut your hose.
PaulH99 said:
Now that makes more sense. Thank you for the drawing! You're using this as crazy "Y" adapter because there are three different hose sizes involved. Is the over-blade dust collection effective on the DeWalt table saw?
If your expecting a clean table, it isn't going to happen.  I helps more so with airborne particles, bigger pieces still end up on the table depending on the material, type and size of the cut.
I used hose from a 1 1/2" kit purchased at Lowe's with one end fits over the blade guard fitting.  I used an adapter from some other kit I had that screw on to that size hose also.  I bushed down the 2 1/2" "Y" adapter with PVC pipe/fittings with a 1 degree tapered hole for a snug fit.  I used another PVC cap fitting with a 1 degree taper to cap the opening when not in use.  The other opening I used PVC pipe and nylon to bush down for a 1 1/4" hose on a Fein vacuum with another 1 degree tapered hole.  As mentioned above, I lose vacuum up at the blade guard for some reason but it's stronger at the "Y" fitting! [unsure]
