venk67
- Oct 28, 2010
Am making a very simple " train table for my son" using a chinese grade birch plywood.
Wife wants dark stain so my plan is:
Sand to 120 grit
Pre-seal with diluted shellac (Denatured alcohol diluted (50:50) with dewaxed ( if that is right term) Shellac to reduce blotchiness of stain)
Then use gelstain ( Java from general finishes) ( which I plan to slightly dilute with some paint thinner)
If that is enough I plan to sand with 220 grit sandpaper lightly then apply a couple of coats of the water based poly finish from General finishes ( exterior 450-since I have some).
Questions: 1. Any point in sanding intially to 180, or will that negatively affect the stain uptake
2. any tips for applying the water based top coat- was planning on using a foam brush ? Bad idea??
3. Can I buff the top coat with a buffer once the final top coat is done?
Venk
Sand to 120 grit
Venk
