GaryLaroff
- Sep 23, 2008
This should probably later be moved to the Finishing thread but I would like to get high visibility and a number of ideas offered.
I am making a large mahogany cabinet and the sides are stiles, rails and panels. My question regards "rubbing out" or polishing of the panels.
The panels are crotch mahogany veneer from the same flitch on 3/8 MDF and are as close to dead flat as I could make them. The veneer is not ideal and shows some grooves between wild grain sections. Both sides of each panel are veneered with the mirror image veneer to give the panel a look of solid wood. They were sanded to P400 grit mostly with the RS-2E and Brilliant-2 abrasive.
The panels are 11 inches wide and about 12, 26 and 40 inches long. The finish is BLO (boiled linseed oil) with pseudo-French polish of shellac over the damp oil. The grain in the panels was not filled but the shellac was padded on by hand. I mix my own de-waxed shellac and padded on 42 - 48 super-thin coats in a continuous session resulting in a fairly smooth but very thin clear shellac coat. The finish is sometimes very shiny and sometimes shows some dull but clear streaks. I would like to make the surface more uniform without garish glare but remain crystal clear and not be steel-wooled dull. Then it will be waxed.
The question is what process to use and whether I just go about it by hand with wet/dry paper or if I can use Festool sanders and abrasives.
I have most of the Festool sanders and quite a lot of the abrasives. I think the sanders include RO 125 FEQ, ETS 150/3, ETS 125, RTS 400, RS 2E and LS 130. I have a lot of the finer abrasives including Festool and Mirka Abranet (for the ETS 125). I also have a good stock of Platin2 S400 to S2000 for the ETS 150/3 as well as a Stickfix "STF-D 150/M8 SW" buffing pad for the ETS 150/3. I could get a box of Platin S4000 locally but would have to buy the whole box which is over $50.
Considering the panels are not large, the shellac is fairly thin and I also have pumice, rottenstone, oil, water and rags, what do you suggest as a method of attack?
Thank you in advance for your suggestions,
Gary Laroff
Portland, Oregon
Gary Laroff
Portland, Oregon
