New 8mm Bits from Ultra-Shear
jeffinsgf
Retailer
Northeast Ohio
Woodpeckers president, Rich Hummel, spent some time in the Shaper booth at AWFS in Las Vegas. He came home fired up about producing more 8mm shank bits for the Shaper/Festool community. A few months ago we launched Variable Helix bits in 1/2" and 1/4" shank. What's unique about Variable Helix is how well they behave in long cut lengths for mortising and tenoning. We began experimenting with them for our Multi-Router and the PantoRouter. As soon as Rich hit the door this morning, he had the prototype team working on 8mm Variable Helix bits. I literally just came back to my office from testing them with the Origin and they are amazing. In less than 2 weeks we will be shipping 8mm Variable Helix straight bits with cut lengths of 20, 25 and 35mm.
Variable helix or odd flute geometry has been a secret for reaming very round holes for a long time. They only became commercially available around 2004 or so. Prior to that, it was either a custom made to order run, or you hade to either modify existing or make you own for the particular job. Only 2 degrees radial difference is enough to make it work. New things are being investigated all the time, and new innovations with very slight changes . are showing to have a significant impact on the life of tools as well. Like in the root of the gullet cut, instead of being a constant depth, making it a variable depth with a slight ramp up then down, kicks the chips off the root of the cutter, making it cooler cutting, and a longer tool life. An existing constant gullet cutter can be modified with a diamond ball mounted point, and just make some relief scallops on the length. They only need to be mm to mm deep to have a significant impact. They behave like a corner chip breaker in a way.
