New assortmentsystainer for Domino!
amcore
I just found this! coming in april! For domino 500!
I just had a conversation with my wife yesterday where I essentially said that I wasn't looking to buy any festool stuff for a while. This could make me a liar.
That's a good find, cross posted to the Festool Talk Group.
They are on the UK site toohttps://www.festool.co.uk/products/new-products/new-products/203166---kv-d850
203166 Corner connection KV D8/50 £82.80
203168 Corner connection KV-LR32 D8/50 £65.80
203167 Centre panel connector MSV D8/25 £58.40
203169 Centre panel connector MSV-LR32 D8/25 £52.65
203170 DOMINO connector range KV-SYS D8 £314.10
203164 Drilling template BS-KV D15 for DF 500 £56.90
Oh man.
I thought with the announcement through, I might be able to get calmer on the purchasing front. ;)
But this thing looks NICE!
They are COOL!  Saw them back in the fall.  I did not play with them.  These types of things I need to have in my hands for a bit and then go over them at my own time and speed.
Michael Kellough said:
Svar said:
So, it needs a domino machine AND a drill to install?
I might have a drill...
This type of connection is hardly a novelty. IMHO the greatest advantage of the DF700 connector set is that both tenons and connectors are installed with the same tool making it accurate and quick. With the new set you have to juggle between DF, drill, and a drilling jig. Still nice, but not as nice as the old set. Also, seems only for 90/180 deg. joints (look at the drilling jig). Could have simply made it a mini version of the old connectors.
@Svar There are different connectors available. The drill jig is only to generate the „access hole“ to the connector...
grobkuschelig said:
[member=15585]Svar[/member] There are different connectors available. The drill jig is only to generate the „access hole“ to the connector...
Not quite. The connector itself (part with the set screw) is round and sits in a round hole.
Woo-hoo!  These might be just the thing for the shelving I want to build in my new office.
Do we know if it's a general worldwide release yet, or just in select markets?
Well thought out solution.  Great solution to a challenge.  Near full proof design.  Sort of expensive.  But likely a big time saver.  In other words, typical Festool kit.  Count me in assuming this is NAINA (not available in North America).
Shoot...and to think I’ve been fumbling around with these things.
Darn it. I have a project I'm working on that I was just going to finish this month. I really don't want to wait around until April. I NEED THIS NOW.
People have been asking for this for a while and it was discussed that it wouldn't be practical because of the size of the 500 mortises. Now it's here and I see complaints about needing a drill and jig. Can't have it all.
If it takes a little longer to do the operation(s) to get a take-down assembly I don't see the issue. Sure beats the alternative of not being able to take apart and re-assemble.
Isn't this actually easier than the setup for the 700? I've never personally used the larger connector system, but it seems like you have to adjust the plunge and fence depths between doing the mortise and setting the access hole. This removes the need to switch between two depths on your domino, not to mention the fact that the drill jig is self centering as opposed to needing to scribe a line around a corner. I also prefer the circular access holes, seems like you could probably make some nice wooden plugs rather easily.
amcore said:
For domino 500!
Even better: as I read the label on the systainer it's 'D8', which means it should work with both Domino 500 and 700XL.
(I would be very surprised should Festool have designed it to only work with the 500)
By the looks of it they recycled the general form of the domino systainers, just made the trays more shallow as it's only a SYS-1 (the existing ones are SYS-2) - hopefully that systainer will be made available on it's own as I would like to have some of them to replace the bigger ones (which are to big for my needs, but not big enough to compress the full 4-14 mm range into one) I have to save some space when taking the domino to a job.
Downside is the price point: >2€ per connector dosn't make it that attractive, compared to existing systems.
+1. Even though I don't foresee using this kind of fastener myself, it offers an option and ultimately it enhances the value of the tool.
This kind of connector also looks stronger than the typical IKEa stuff.
