Welp. The battery powered Domino is a real thing I guess.
Yesterday as I was cutting mortises with my Domino 500, I kept stepping on the cord, which impeded movement.
I know it's user error, but the way the cord flopped around on the floor, it kept moving to where I would stand to make a cut.
I didn't have that issue with the hose.
I have used the green clips to run the cord along the hose, but the clips catch on the edge of my MFT and assembly table.
So yeah, yesterday between grumbling and cursing, I was thinking that a cordless Domino might be nice.
I know I may be more clumsy than many of you...
I have a pivoting hook arrangement for the hose with the cord clipped to it. That way it doe snot catch on things.
I have a 1x3 with a screw eye and bungie cord on top.
I clamp it to my MFT. It works well but gets in the way when i cross cut wide panels.
Since it was down and out of the way, and I was in production mode, I didn't want to stop. Haha, it was easier to batch and moan.
I use large shrink wrap to keep my hose and cord paired...a "poor man's" version of the OEM combo...and also have the heavier cord on it so it works with "all the tools". The last two wraps are velcro so I can adjust better and also contain the plug-it end when I'm using with a fixed cord tool like my old ATF-55 tracksaw.
I'm betting we'll be able to just buy the fence as a standalone option.
I don't know if it is a quick/easy swap-out...the construction is completely different which may mean the attachment method is also different. Here's the 500 vs the 500 R.
holy crap are you guys me? I've been embarrassed to tell anyone about my bungie -pivot hook -screw eye arrangement but it works so well
i strap the power cord to the hose with these guys spaced every 2-3ft. it takes a min but does not impede use
Sounds like a good approach. Today I was using my track saw, and I used the green clips to attach the cord to the hose. Took them off after a minute since they catch on the end of the guide rail. (Another victim of YouTube influencers.)
I like the idea of velcro straps and am going to buy some.
It wont be long and corded tools will be of the past only hand held tools. It places like Bunnings and Sydney tools, when the corded models sell out, they will only be stocking battery powered. Even the shopvacs are on batteries. Festool probably has been planning the move to battery tools for quite some time, but wait for existing stock numbers to dwindle before introducing them. No idea how many Domino tools are sold, my guess is not very many compared to biscuit joiners for example.
For me, I like the corded model, and no intention of doing work with the DF700 outside of the shop are anyways. I won't be getting cordless Festool gear. Already have 2 battery systems and don't want a 3rd. Got Ryobi and Dewalt battery tools already.
I have a few vacuum cords and only 1 is clipped, with 3d printed clips from China. The others have velcro every 300mm or so. The straps came from the local hardware store. It wraps around the cord then around the hose and onto itself. It's very secure. The hose with the printed clips is only used on the DF700. All other tools get the velcro hoses.
I'm as dubious of that as I am of the Jet Backpacks we were all promised we'd be using by the year 2000 when I was a kid!
I reckon unless they come up with a battery that charges in seconds and lasts for a full days load, there will always be requirements for corded tools. Or they could even start supplying AC-DC convertors so you can run them off mains.
The corded DF700 is already too heavy for me to include in my tool arsenal (I found a work-around with my DF500 to do what the DF700 can do in one of my projects).
Thanks but no thanks.
Here in NZ, the stores have very few corded tools at all. Even the 10inch bench saws are battery powered, as well as the Dewalt Makita etc 12 inch drop saws are all Brushless battery tools. Only the cheap ones use brush motors now. The brushless models last longer on a battery compared to the brushed motor models.
Cordless tools have had a bigger impact on pneumatic tool use especially in the automotive sector. My son started work as a tech 21 years ago and used air tools exclusively but today it is a rare occasion when he uses an air tool instead of cordless. Me in my hobby workshop, the only cordless tools I have are drills of various types and my sole corded drill gets used every couple of years. I saw and bought my first 7.2v Makita drill in 1980 and I have never regreted it. I don't see the point of cordless for stationery tools which are not used outside the workshop but for a tradesman they are just about essential these days.
@Mini Me Those 7.2v Makita's were a killer product at the time, unbreakable and even though the batteries were NiCads, they lasted and performed very well.
I can well understand air tools being replaced en masse in the automotive industry, use loads of air, horribly loud and usually at a disgustingly high whiny pitch for the sanders, grinders, etc. The only good thing about them is they're usually fairly cheap, but I got rid of pretty much all my pneumatic tools for those reasons.
Considering you still really need to use extraction with the Domino to both clear the mortise and preserve tooling life, I see little point in a battery operated version. But yea, they must perceive a market opportunity.
Festool make a cordless extractor and a lot of building sites aren't exactly knocking their pans in to provide reliable corded power nowadays.
Possible use in a shopfitter situation.
Exactly, Festool's primary market is the trades but a lot of hobbyists won't accept that.
Ya, I'm thinking filler strips with one of the cordless vacs would be a nice mix. However, it'd be hard to beat a cordless Zeta P2 for that type of work. That said, I can make the case that the domino (with its loose setting) is much better to do field work with if you've lost your strike lines or they're in a bad place to transfer and you need to make something new on the spot because someone forgot to measure at multiple places along the wall. :P
Nah the corded tools will stay alive for a loooong time. The value of cordless tools is determined by the availability and pricing of batteries and chargers. Older model cordless tools have a nihil resale value when the batteries are dead.
The declining popularity is also due to companies not applying new tech to the corded models.
And of course the insane regulations on corded tools for workplace use vs battery powered ones.
I'd personally like to see them put the new tech in more corded tools. That's what Festool did when they released the ETS EC series sanders 10 years ago. And it could be argued that those sanders are still one of if not the best RO sander available...and it's corded. 🤔
I can certainly see that scenario, although I wonder what kind of work would be underway where Domino is material when the fit=out is pre-electrics.
Seemed like they just did that with the HKC
