- Nov 3, 2007
LOML decided that we needed new countertops, and we probably did.
I'm going to try to keep this short so I don't bore you but the story that leads into this is somewhat interesting.
I made a series of cutting boards out of sink-cuts from apartment building projects, where I used 1-1/2" Boos hard maple slabs for the countertops. So these cutting boards were pretty stout and heavy.
Anyway, we kept one and it was normal to dry it vertically on our sink after use and washing. I bumped it once while in that position and it fell with a mighty thud right on the hot water valve of the, then current, kitchen sink faucet set....
Prior to this particular disaster, I would not have thought that one, seemingly innocent action, could blow that valve apart and cause a geyser to erupt with hot water. I immediately went below the sink and started cranking on the existing shut-off valve. It took a while and I finally got the hot spewing water stopped.
That was when I realized that quarter-turn valves are worth the extra money!
[attachthumb=#1]
I also deal with Rental property and a few recent incidents made me realize that quarter-turn valves are REALLY worth their premium (even replacing old working valves) in rentals.
EDIT: I forgot to add that while changing out the faucet, the whole sink came loose. It has been rusting and nasty for years so we determined that we needed a new sink. Then I was informed that we needed an undermount sink. That lead to needing new countertops, which lead to this thread.
[attachthumb=#1]
