jonny round boy
- Jul 21, 2007
I've just stumbled across this whilst looking for something else, and I don't remember reading about it on here so thought I'd post it.
It seems Festool have released some new blades for the TS55, but with a thinner kerf of 1.8mm. Presumably this is for better battery life with the TSC, but these would also work with the mains version.
There's an 18-tooth 'Standard' blade, 500458; a 32-tooth 'Fine' blade, 500459; and a 12-tooth 'Panther' blade, 500460.
All showing as being available from 1st April.
0.4mm doesn't sound like much, but it's roughly an 18% reduction from the existing 'standard' 2.2mm kerf, so should help significantly with battery life. I'm not sure if the new 'fine' blade with 32 teeth would give as good of a cut as the normal 48 teeth 'fine' blade, but I'm guessing that will also help with battery life.
Apologies if this has been posted before & I just missed it (which is entirely possible!).
